Discuss Lucien's most challenging picture puzzle yet... what does this box do? in the UK Electrical Forum area at ElectriciansForums.net
Lucien Nunes
Mentor
You've seen some curious stuff in my vintage picture puzzles before but what can you make of this black box? I want to know not only what's inside but also its main electrical specifications; there are two in particular for which I need the actual figures.
There will be a few picture clues to help you along...
Not a transformer. Here's your first clue:
Would it be a pressure/water head level switch sensor/switch? I'm guessing there is a pipe from the big one into the box and then the rusty small one is a vent to allow the water to rise.
The box is maybe a mile away and has no pipes connected to it, only cables.
No sumps or pumps needed here Pete. Although the clues provide information relating to the use of the box, they aren't necessarily part of its functionality.
Those robust metal stays and the strong wooden shelf do give the impression that the box contains a beefy transformer or ballast. In fact I was able to lift it off while standing on a stepladder and pass it down to someone.
Looks like the lid of the box has a lid which clamps down and possibly seals so that it is airtight?
I know, it's your tool box with all your best tools inside, I knew all along your just a closet tool tart. Or you have been to Oak Island and found the Templar Treasure.
Looking at picture in #6 one can see:
1. A view looking down to terra firma.
2. Large diameter pipe - so perhaps high volume and low pressure flow. So possibly water in it.
3. A small bore (1") vertical pipe above the larger pipe with a right angle bend into what might be a chamber. Thoughts are: an overflow?, vent?, pressure relief?, or connected to something else to sense level or pressure?
4. Midway up on the left side is what looks a bit like a copper earth electrode, so straight and regular it appears. Or is it a small bore pipe?
The thin thing is the handle of a rake, and the small pipe is a vent. These details aren't really of any importance. The presence and function of the big pipe help to set the scene and give some insight into the electrical situation that will become more apparent in the next pic. In the meantime, I have some work to do.
Reply to Lucien's most challenging picture puzzle yet... what does this box do? in the UK Electrical Forum area at ElectriciansForums.net
I have been carrying out an EICR on a property and have come across this black tarry substance on 2 of the cables. I have seen the pitch oozing...
4K
So a quick catch up so you can get an idea… I was asked to do a job for another electrician, as he is too busy. I’m busy myself but said I’d...
Thank you in advance for your help. I recently purchased a home and while removing some built-ins I found that they had a 14/2 wire running...
I hope this is the right place to post this, please redirect me if not. I've spent quite some time reading the forums, so I apologize if I've...
Hoping someone might find this a challenging puzzle - I'd be grateful for any help and sorry in advance for the lengthy description! I think...
