Looks like the sheath on the outer cable has been nicked by whoever drilled the hole?View attachment 86766
Good eyes. It has just about but not penetrated inner sheath. Is that good to leave or is there anything I can do aside from cut out and repair?
Note, I've put my tin hat on.
I'd wrap a couple of layers of tape around it neatly. That's assuming the damage has definitely not gone right through the outer sheathing.
Tis what I'm thinking and tin hat is right ? is there anything I should mark on the tape to let a future electrician know why it's been taped or just not the done thing?
I would skin up a 150mm length of the outer sheath of a 16mm swa cable and fix that over it.
But I'm no electrician so could be speaking out of my backside ?
If there is enough slack in the cable I would be tempted to do the same as you have to the others, but that's me, belt and braces.
I knew you'd go that way Mike. Be interesting to see what the general consensus is.
I accept my way is technically a bodge, but I think it's acceptable. Again, with my tin hat on. It avoids several joints which are potential failure points.
Thank you all. I will go the tape route, acknowledging it's not the ideal treatment but one as the property owner am happy with but also know that no-one is drilling into that wall for the next 50 years as I plan to die in this house :)
To complete the loop, the TV is now mounted on the wall and all working fine. I've completed the coax routing check around the house with the aid of a great little (and cheap) device from Klein tools (https://www.amazon.co.uk/gp/product/B076DP1534/ref=ppx_yo_dt_b_asin_image_o08_s01?ie=UTF8&psc=1)
Next on the to do list is to check all the CAT5/6 terminals although I've already come across helpful labelling such as "does not work" :) :)
Oh...and my wall scanner arrived so hopefully no more crimping (famous last words)
As an Amazon Associate we earn from qualifying purchases.
Right...so I've got a cable route which has some coax, ethernet and these two random white cables with brown and blue wires terminated in a chocbox.
For life of me can't figure out why they were routed there or what they do. Anyone have a guess where they may be routed near a TV location? Hopefully can use that information to figure out where they end up as haven't found the other side yet!
I assume the two co-axial cables are from a dual LNB from a satellite dish to allow signal to a receiver box and allow one programme to be recoded whilst watching a different programme, can't help on the two white cables, perhaps low power cables? have you checked if power is supplied to them?
