Discuss Main bonding to do or not to do in the UK Electrical Forum area at ElectriciansForums.net
When you say portacabin is this just a shell container or a lined out one as you see as site offices, canteens etc?
Why the optimistic Pete? the reason I asked was that if it was a kitted out unit with an existing consumer unit the metal container shell is bonded to the consumer unit.
Just optimistic that the OP was aware of what you were saying nothing against you Mate
We are required to bond extraneous-conductive-parts which are likely to introduce a potential.
If the port a cabin is extraneous, conductive and likely to introduce a potential, then bond it.
If it isn’t any one of the 3, then don’t bond it.
Reply to Main bonding to do or not to do in the UK Electrical Forum area at ElectriciansForums.net
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Hi all, I have a log cabin in my garden. An electrician ran an armoured cable from my consumer unit to the log cabin and this terminates on the...
Hi all, I would like some advice on a scenario currently at my workplace. I am replacing a Sub main DB and replacing the wiring to sockets/lights...
I'm starting a new construction single-family residence, I know with the 2020 NEC they require an emergency disconnect on the exterior of the...
Hi All I'm new here. I have just finished my NVQ and waiting to do my AM2. I have a question on selectivity as it has always slightly confused me...
