main bonding to gas and water can they be conected to the earthclamp with a crimp or do they
have to be conected directly to the clamp is there a reg or is it good practice to conect directly help reqiured please
Crimp Far better connection and dont pull out far better connection im sure there is a reg but cant think of it at the mo
If i am using one bond for both, i put the screw through the cable on the first connection, and the a ring crimp on the last.
Good point jason i do the same my self saves cable ,to use a single cable for both services it has to be a continuose lengths so as jason has said
It is good practise to crimp a lug on the end,however the clamps are designed for clamping the bared cable
So its a matter of personal choice
If you mean as one cable for both services as a continuous cable, then as Jasons method
main earth to water, gas
stumas,
Des 56,
