Discuss Main Fuse is apparently ancient in the UK Electrical Forum area at ElectriciansForums.net
I could be wrong, but the OP mentioned that He/She was, didn't like fiddling with fuse wire, I took it that the OP was on about replacing the CU and the "Electrician " for some reason only He knows decided that the cut out needed up grading, and the OP was of the opinion that it was not possible to change the CU, at least that is how I took it perhaps the OP could clarify the situation.
Reply to Main Fuse is apparently ancient in the UK Electrical Forum area at ElectriciansForums.net
