Discuss Main Protective Bonding Conductor question in the UK Electrical Forum area at ElectriciansForums.net
SparkyAndGeorge
Hi guys
Would appreciate your comments on the following.. I am currently involved in the refurbishment of a building with 2 service heads (both in use) but only one gas intake and one water intake. What are the main bonding requirements in this situation? I am assuming both MET's require a bonding cable to the gas and water intakes? Many thanks in advance.
Hi guys
Without eyes on this install, it's difficult to assess, use the MET related to the service head you are relying on???? Anyone??
1 to the gas, 1 to the water?
Seriously though, why is there 2 electrical services if its only one property? Speak to the supplier and see if it can be combined to just one.
Separate supplies to separate buildings? How does the installation itself have the electrics separated?
If one electrical supply serves the building with water, and the other doesn't... then take the bond from there.
Multiple incoming supplies should have their earth's linked subject to the DNO's requirements.
Main bonding from each MET to the point at which services enter each installation.
Reply to Main Protective Bonding Conductor question in the UK Electrical Forum area at ElectriciansForums.net
Hi there, Just a quick question. Does a main protective bonding conductor require UV protection when run outside? I am under the impression that...
Been looking at a CU change in a small office and would appreciate comments on the following. Office is supplied from the mains intake in the...
6K
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
What are the regulations requirements on Earth bonding ? I am currently planning a 1st fix re wire I have the following setup Gas Meter...
Essentially I have a "normal" socket in a ring mains, i.e. one 2.5mm T&E going in and one 2.5mm T&E going out. I am looking to simply add two more...
