T
tuckerkop81
Guys, need some advice.
When measuring across some cctv cables, im getting around 0.80 v of AC, which in turn is causing mass problems with the system.
I have seen in our basement that the lv cables are run less than 2 inches away from the mains cables, so im sure the magnetic field is inducing the lv cables.
question being would a rubber mat between the 2 cables stop the magnetic field or is there another solution???
The run is around 20m in length
Any help would be greatly appreciated
Tom
Tom
