I
iamelectric
Am i correct in saying that its ok to install 230v downlights in zone1 of a bathroom
What`s their IP rating, is there supplementary bonding in place, RCD protection in place, Do the manufacturers instructions say that they are suitable for the location, are you fitting them, are you modifying the circuit, are you competent? So many other factors
Personally mate I only fit IP rated downlights in bathrooms, you don't want a call in 6 months cause they are knackered! Steam moisture etc. charge a little extra for them as nowadays there is not a massive difference in price IMHO .
thanks for the advice , just checked it i am outside zone1 and 2 so fittings i have are fine
So am I correct thinking I could put 240v spots in a bathroom if there ip65 rated? Or would they have to be 12v
yes 240v fittings are fine as long as they are ip65 or ipx5 , you can also use standard ones if the ceiling is higher than 2.25m
