Discuss Max load on 850watt dimmer in the Australia area at ElectriciansForums.net
H
HUD
? trying to work out max load on 800watt dimmer with 50watt low voltage down lights have to calculate the load by the amount of 60va transformers instead of the lamp watts not sure how to convert the amount of 60va transformers into max watts for the dimmer
thanks i had asked for a 1000 watt dimmer but ended up with 800 watt dimmer and i have exactly 13 to dim thanks for your help
It will probably buzz and get warm.work for a while and then depart, to go where all burnt out dimmers go,no not to meet its maker,the bin of course
I would persue the 1000 watt version to allow for a reduced percentage of the dimmers capacity,it will die you know :eek:
Reply to Max load on 850watt dimmer in the Australia area at ElectriciansForums.net
I have halogen lights in my kitchen under the wall units, there are ten lights altogether bulbs are either 10 watt or 20 watt G4 bulbs ( not sure...
Hello! I design and build lamps, which has been a simple task so far, but I've decided to dip my toe into the dubious world of 120v LED PCBs for...
I am looking at installation of an architectural dimmer, that is will supply 6 channels, with 20A circuits each (2400W ea). Our hall has can light...
I am sending power to some 5v led lights about 50ft from the transformer. I was going to use some CAT6 direct Burial cable that I kept after a...
Hi everyone, I need help installing a Lorex smart doorbell. I have tried to install a doorbell transformer several times to no avail. The first...
