Worcester
Mentor
Thinking of getting MCS certified?
The Microgeneration Certification Scheme aka MCS have now published their own QMS, so i guess if you follow it you should be compliant. (well maybe !)
Microgeneration Certification Scheme - QMS Templates - http://www.microgenerationcertification.org/mcs-standards/qms-templates
p.s. one of the links is wrong (well what would you expect from someone publishing a QMS :) :) )
The link to the Installer Sole Trader Documented Procedure should be:
http://www.microgenerationcertifica...-Trader-Documented-Procedure-Manual-FINAL.doc
Just done some forensics on the documents, and the originators are NAPIT Services Ltd :) - So its an updated version of the QMS that upon request NAPIT issues to it's members
Assuming you have looked through this, is the Sole Trader route different? I have just got my initial MCS with Napit (again) and complained about the procedure for a sole trader doing maybe 10-20 installs a year being the same as a company with a fleet of salesmen doing hundreds.
Rules and routes are the same! Just means that as a sole trader you have to be superman :)
Worcester
Mentor
Worcestershire
Website
http://WorcesterRenewables.com
MCS Publish QMS !
Green Energy Forums | Green Energy Hub
Worcester,
Worcester,
