Discuss measurements on a three phase distribution board in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
hi can you anyone help i had to undertake measurements on a simulated 3 phase distribution system it had main switch, bus bar then went to 3 sockets we had to take test with all the sockets on and then turn one off and test it all the readings where different L1 L2 L3 and n (3kw) L1 4.87 L2 4.95 L3 4.86 and n 0.2 all sockets on L1 4.84 L2 5.00 L3 0.00 N 4.95 one socket off . do you have an explanation off the difference between the measurements recorded many thanks would be greatful if you had the answer
Reply to measurements on a three phase distribution board in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hello All
So I'm not long out of my college days and unfortunately I didn't have a lot of exposure to three phase and commercial wiring systems...
I have a scenario where there is a three phase DB in a commercial property where there are mixture of three phase and single phase washing...
Hello,
Looking for some advice following a botched 3 phase upgrade today. Some background:
Commercial unit originally fitted out (4 years ago)...
Hello,
I’m testing some electric meters.
As the circuits have no load on them to prove each ct I’ve plugged a hair dryer to simulate a load and...
