A
alannotts
Can there be a combination of meters inside and outside the building. For example I have flats above a shop the, shop has its meters on the outside wall, due to the available space its better that the meters for the flats go inside the flats. The supplier of the meters and electric thinks its not possible to have some meters outside and some inside even though they are seperate entities, the reason given was due to safety of isolation in an emergency?
I welcome your views.
Thank You A
Thank You A
