Discuss Move two way light switch in the Lighting Forum area at ElectriciansForums.net
Borat1987
Hi,
I need to move a two way light switch from one side of a breeze block wall to another.....there isn’t enough length on the existing cable to feed it though. So I’m going to need to use electrical blocks to extend the cable, then feed the new length through. Do I need to use an electrical block for each individual cable or can I group them together and then use a single cable on the other end of the block and just feed that through. If I can what grading of cable would I need?
any help would be appreciated.
thanks
Dan
Reply to Move two way light switch in the Lighting Forum area at ElectriciansForums.net
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
Thinking a 240V AC relay activated by two independent light switches could be used to switch power to a shared inline extractor fan. The fan...
I can't seem to find the right answer for a smart switch installation for a light that has THREE switches. There's conflicting information, and...
I'm considering using several of the remote WiFi switch sets to control a group of five different lights. The existing switches are all grouped...
