B
ben2012
quick question as im not 100% sure, ive been asked to move a 3ph board from one side of a wall to the other side of the wall. now the set up is SWA glanded off into a 6x6 metal trunking running from top to bottom of the wall. supply then goes into an isolator, out of isolator into a meter and into dis board (in single insulated cables). my idea is to pull cables out of dis board, drill through back of metal trunking putting plastic pipe through wall then streight into back of dis board. question is would i need an isolator on the other side of the wall before it goes into dis board? (the room it is currently in, is only accessed via another business premises)
sorry for the long winded question!
thanks
thanks
