A
ainsdale_gas
I am a fully qualified and exerienced gas engineer currently sitting a part p defined scope course and I require advice please on which tester to purchase.
I have narrowed it down to the metrel mi3000 easiplus, megger 1710 or second hand 1552.
I would like to save money by purchasing the metrel and I like how it comes with rechargable batteries and the help function on the lcd but I don't think I'll need it? We use meggers in the college and I like with their rotary switches they are very simple to use.
I know people will say I can't go wrong with the 1552 but are some of the extra functions on the easitest or 1710 worth it? Does the 1552 come with rechargables?
I'll appreciate any advice, thank you :)
None of the Megger 1550 series testers come with rechargeable batteries as far as i'm aware. They are however good solid test meters and will serve you well (currently own the 1553 which is now 4 years old). Tbh you won't go through batteries too quickly and the meter tells you the voltage being produced by the batteries every time you switch it on. Once it's creeping towards 9V it's worth buying yourself a new pack of batteries before it refuses to carry out anymore IR tests. Don't know anything about the Metrel so can't comment on that and i assume you'll be saving a wedge buying second hand over a brand new 1710. Ensure you have a current (preferably new) calibration certificate if you buy the second hand meter otherwise you may be buying a pup. Nice to see a gas engineer actually willing to do the defined scope work properly. I know a plumber who connects up his own CH systems, he says he's defined scope but doesn't even own a proper test meter, just a £10 voltage tester!
When I looked into my tester I seem to recall the 1552 has more features than the newer 1710.
However, the new 1710 does do more smart things like only needing 2 wires for non-trip Zs reading.
Exactly Dunc, plumbers and gas engineers may not see the worth it buying a part p tester but it gives me peace of mind and credibility to my customers that I am doing my job properly, no matter how small.
If I go second hand I'll make sure it has an in-date calibration certificate first.
I will speak to test-meter.co.uk as I've seen they advertise on the forum and seem very helpful and good value.
I have seen people say go for the megger 1712 as it has an auto rcd test function which I think the metrel also has. We use the seperate megger loop/rcd and insulation part p test kit which I don't think have this function. With the auto rcd test function does this mean I don't have to keep resetting the rcds as it goes through the ranges of i x 0.5 to x 5 and ramp test?
One of the forum sponsers test-meter.co.uk have a facility to compare different MFTs.
At the moment their Metrel MI3000 is £335.
It's the one I use, has rotary switches like the Megger.
Unfortunately, it doesn't do earth rod testing, or the new type B RCDs.
How common are the new type B RCDs in domestic premises? Does the 1552 do earth rod testing and type B RCDs or would I need a 1710 for that?
When testing earth electrodes, if there is no RCD protection for the installation, then a high degree of acuaracy is required and an earth electrode resistance tester will be required. Some MFTs have this function.
Where there is RCD protection for the installation, as in the vast majority of cases, a high degree of acuaracy is not required, and any MFT or even a simple earth fault loop impedance tester can be used.
As for the type B RCDs, I have yet to come accross one in an installation. They are primarily for use with Building sites, PV installations, UPS installations, Frequency converters and High-frequency power converters.
Just spoke to test-meter.co.uk on the phone and looks like I will be purchasing the Metrel 3100 which is basically the mi3000 but with built in help function and fuse characteristics so which will save time when determining wether my values are correct and pass the test as I still get a bit lost finding my way around the on-site guide.
This Metrel sounds perfect for someone new to this like myself and great value working out at around £443.00 including vat and 5% forum discount, made up. I want to buy it now but I think I'll have to wait until I come back from my holiday at the end of June, though I hope they are still giving out the free volt sticks by then.
Thanks for replies, very happy that I joined the forum as I probably would have missed this great deal otherwise. I'll keep browsing and post again when I need some more tips :)
ainsdale_gas,
ainsdale_gas,
