Sagly
I have a Victorian house with the usual messed up wiring from decades of patching and adding to. The kitchen is in an extension at the rear. There is a single lighting cable supplying the kitchen (not a ring main). Can I run 5 pendants from this cable in series through one light switch?
Going on what you have written above, i would strongly advise getting a local electrician to come and assess the situation and go from there.
It is nothing more than guess work otherwise.
I should hope there is not a ring main feeding the lights!
If the wiring is in that much of a mess then it would be far better to get that checked out and made safe as necessary before thinking about making alterations to the existing circuits
Could be a ring main feeding the lights, or are you on about a RFC
It's the principle of running 5 pendants in series controlled by one switch that I want to check. I have wired them together directly with the switch cable going to the first ceiling rose. I thought afterwards that it might be better to have the switch cable running to a junction box and then to each light in series. Would that be more acceptable?
5 pendants on one switch. How big is the room?
You haven't stated what the current load is on the circuit, nor the load you want to add!
i'd not wire them in series. they'll be dimmer than me, pete999 and geordiespark put together.
It is important to be aware of the correct wiring arrangements and terminology to ensure that the correct information is provided.
To connect five pendant light fittings with a maximum of 100W lamp fitted to each pendant would be a load of about 2A and standard light switches are rated to 10A (though they would not really like to run at ten amps).
The wiring for the lights would be a parallel arrangement, Light 1 live to Light 2 live to Light 3 live etc and Light 1 neutral to Light 2 neutral to Light 3 neutral etc. not a series arrangement of Light 1 live to Light 2 neutral...
Thanks Richard, yes I have wired them in parallel (every day is a school day) so from your explanation the switch would be working at capacity with 5 no. 100W bulbs in the light fittings. Is there any other way to switch them without loading the switch so much?
no. your 5 x 100watt lamps total just over 2A, so the switch will not be overloaded.
Multiple lighting pendants from one feed
DIY Electrical Advice
Thread Tags
Sagly,
telectrix,
