J
johnatfarnham
Does anybody know where a compatible oven thermostat can be obtained for a Neff double oven cooker. This is an old cooker and the E-Nr number 195.303 852 does not now register with any spares supplier. The top oven and grille within it ceased to work. From the temperature regulator switch there is a wire which runs to the thermostat which was an inch long device which had been solders to the end of this wire. From the other end of the thermostat another wire had been soldered and the end of this wire was connected to the oven heater element. I disonnected both ends of this wire and bypassed the thermostat to prove that the heater element was not faulty and indeed it worked which proves the thermostat is not working. But where, oh where, can I find another thermostat. The one that was in there was insulated with a rubber cover and then inserted into a small metal tube mounted on the back of the top of the oven This is a fan oven and the switch shows a temperature range up to 180C. Can anybody tell me where to find a replacement thermostat or at least a compatible one and if it is one that is just a probe how should it be wired.?
Johnatfarnham
Johnatfarnham
