Discuss Network help, wireless extenders in the Computer and Networking Forum area at ElectriciansForums.net
Ok got the following
TP link - tl sg1008p switch
3x linksys ac1200 max wifi extenders
He has a bthub 6 ,
Can i just connect the switch straight into the hub , then cat6 to points in the house then plug the extended in
I have the extenders plunged into the hub but can't seem to connect ??
You think I need to change the hub for a router ?
I fitted the switch and existing extenders work fine though it , can't seem to get the link says ones to work .
Hi - just on the extenders bit - I have seen these not connect due to wifi security issues, so I would remove all security and reset. Once it's working then security can be sorted step by step. Hope that helps.
can't connect to the hubs and get to admin, but they won't connect to the BThub6, its doing me fooking head in. is this the right switch i how
I've just come out of the back of the bathtub to this switch, then cat6's out from that to rj points
cheers
grand
Reply to Network help, wireless extenders in the Computer and Networking Forum area at ElectriciansForums.net
Hi all I’m after a bit of advice regarding wifi/secondary router. Data is not a strong point of mine so any advice would be very much...
At the moment it depends on the weather on how well the central heating works, the main problem is the Nest Gen 3 thermostat only measures the...
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
Hi guys, I could use your expertise. I have an old automatic pool cover, kept in storage for 30+ years, in good condition, and worked well last...
