Got a neutral to earth fault on a ring final which is tripping the RCD instantly when trying to reset.
Tested at the board and I’ve got continuity between neutral and CPC. Disconnected the ring and split it into two legs and identified the faulty side.
This only started happening after I installed a new cooker circuit, although I haven’t used any fixings that could have damaged cables. Not sure if that’s just a coincidence or related.
I’ve unplugged everything I can think of on the circuit so I don’t believe it’s appliance related.
Before I start lifting loads of sockets, has anyone got any quicker methods or tricks to pinpoint the fault with minimal disturbance?
Any advice appreciated.
