I am sure it says in the regs that it is good practice to take a neutral to the switch to accommodate electronic devices being fitted in future.
OK..
i recently installed a load of 600X600 florrys in a gospel church split across 3 phases
did em 3 plate....
but i would have had no issues with jointing the neutral through the switch....
what you have to remember here is its an accessable joint....within barriers/enclosures yes....?
so whats up...?
after all it should only be skilled/instructed persons accessing the switches...yes?...
so whats up...?
after all it should only be skilled/instructed persons accessing the switches...yes?...[/QUOTE]
nope, should be only competent, qualified persons sticking their mitts in thew switches.
Thanks for pointing that out, never noticed that, didn't actually think people actually looked at profiles on here, will have to put a picture up of a little dog like you
Thanks for pointing that out, never noticed that, didn't actually think people actually looked at profiles on here, will have to put a picture up ofa little dog like you
Tanna
Now that is either sarcastic with a sly bite,or a compliment by a fellow dog lover
I suppose it all depends on where the comma would go
just rewired a new house this past week have fed the switches so neutral in every switch as the customer intends to add decrative plaster roses to all the rooms so how wouls I do this with the loop in method and have three or four twin and earths to connect and I don't want junction boxes under floors, cant see any reason for not putting neutral in switches as lots of the switches are back to back anyway and it saved a lot of cable runs
The same way it's been done for donkey's years!! Do you think that decorative plaster ceiling roses are a new idea!!
How do you work out that loop feeding through the switches saves on cable, when your going to need at least two cable drops and more often than not three at each switch??
it saves on cable mate because all three walls in the property meet at the same pilar got to be better than putting three 1.5mm cables through a plaster rose, there is no reason to not put neutrals in switches its common place in US and Europe
