it saves on cable mate because all three walls in the property meet at the same pilar got to be better than putting three 1.5mm cables through a plaster rose, there is no reason to not put neutrals in switches its common place in US and Europe
One case in a hundred you may save a bit of cable, other than that you Ain't, you'll be using More!!!
Wrong in Europe they generally use a central JB in domestics and small commercials and the States, well that's some sort of recommendation if ever i've heard one!! lol!!
