Jones Concepts
- Reaction score
- 2
Discuss New bath fan install to 4 wire connection in the DIY Electrical Advice area at ElectriciansForums.net
CorrectDoes the fan not function.
Original fixture was light, heater and fan (3 switches). I'll post a photo soon. Yes, both green tabs are labeled Ground.Did the original fan have a light on it and how many positions is the switch, one or two. Can you show the wiring at the switch. I assume the tabs on the greens say ground connection.
Well, this doesn't look right...Can't see how that cable provided three functions as it only has one neutral and two hots.
If it makes things any easier, I can rewire all of this to just 1 switch. It's only a fan now.It looks like someone has used the ground as neutral so some reconnecting is required, I thought the cable didn't have enough cores for its previous purpose. Give me a bit and I will look closer.
That did it! I also omitted that dial timer. Thanks for the help.Disconnect the white from the switch and connect it to the other white (The ground currently connected to this white reconnect to the other ground) then see what happens.
Reply to New bath fan install to 4 wire connection in the DIY Electrical Advice area at ElectriciansForums.net
