Discuss New build - DNO fuse size in the UK Electrical Forum area at ElectriciansForums.net
Good morning one and all,
I have a new build coming up (Hertfordshire) and was wondering what size fuse the supplier install now?
The reason why I’m asking is because a sub main is required due to the client not wanting the CU near the meter.
thanks,
80A seems to be pretty standard, I've even seen some 60A's from new. But ask yourself when the install is going to be pulling 23kW..........
thanks,
Ask the D/N/O.
Thank you for all the replies.
It’s a 3 bedroom small end of terraced house.
I suppose regardless of 100a or 80a I’ll still need to wrestle a 25mm 3 core inside the meter cupboard.
60a would mean I could get away with a 16mm.
I’ll give them a buzz.
thanks
thanks
You're welcome, Mate good luck
thanks
80A = 16mm..... unless there's more to the story?
thanks
Why do you need to wrestle with 25mm 3 core?
What size submain are you installing? The size of the DNO's fuse does not dictate what size fuse you put in your switch fuse.
Reply to New build - DNO fuse size in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
DNO ripped out antique main incomer/breaker .The guy hated us and himself and everyone else by the end of the job ! . Client going to contact...
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
Hi all. I have been asked to take over a job an electrician has started, and has moved abroad. The house is a big mansion, with a 3PH supply...
4K
So far I have never had to deal with a new supply but a possible site we are looking at will need some major changes and so I wondered if folks...
