NICEIC Certification Scheme
SteveT
Hi there,I have my nic assessment coming up soon and have question regarding certain certificates. I normally use the iet certs that you can print off the net but was wondering if you need to use the nic domestic eic + schedules (green ones)? I was going to buy some but for all the certs I need it will cost nearly £60 for a pad of 25 when hopefully I will only be using 2. I wouldn't imagine that it would be a problem if I didn't use the nic ones but I am trying to cover all bases.Many Thanks,Steve.
You cant buy NIC certs unless your registered. The green certs aren't NIC, they are plain.
Keep using IET certs off the web.
For around £3 on ebay you'll get a CD with every kind of cert imaginable on it, NICEIC, Napit, Elecsa, fire alarm, emergency lighting etc.
You dont have to use NICEIC certs. The cert just has to comply with BS7671 ad the info there in. As has been said you can photocopy the one in the BGB if you like. My NICEIC assessor has never cared what cert I use.
The NIC sell two types of cert pads if you want them, one for members and one for non memebers. Personally I use Form fill as it's free and a good product :)
If you could be so kind and let me know the name of the disk, please.
Cheers guys, didn't think it would be a problem but just want to make sure nothing could be frowned upon. Thanks again,
As long as you have space/columns for all the values obtained i wouldn`t think it matters what form it is........that internet cd sounds like the best option........
