Discuss Niche Lights -flashing like a strobe when switched on - guess needs replacing? in the The Welcome Forum area at ElectriciansForums.net
efemeral
EF Member
claverham
Hi
We have two alcoves with a downward niche light in each. About 4 years old. Pic attached.
Both operate from one switch. One light is flashing like a strobe when switched on - guess needs replacing?
Appears to be a solid unit rather than containing a bulb that can be replaced.
No obvious way of determining make/model.
Any advice would be much appreciated.
Cheers,
John
Strima
Electrician's Arms
St Neots
That's an LED lamp, more than likely the driver has thrown a wobbly and will need replacing. Hopefully it's a self contained unit with integral driver that can be swapped easily.
Midwest
Electrician's Arms
Oxfordshire
Safely isolate the lights. And gently pull the fitting downwards, using your fingertips, moving from side to side until you see a springy thing. Then pull that side down first. Watch out for the springs. They hurt. :)
OP
E
efemeral
EF Member
claverham
Many thanks Strima.
I'll call in an electrician.
Cheers, John
Murdoch
Regular EF Member
Woking
That looks like a JCC sealed unit and may have a 10 year warranty on it.
When was it installed?
Murdoch
Regular EF Member
Woking
OP
E
efemeral
EF Member
claverham
What did the spock say about the warranty on these?
Can't remember - there was so much going on.
If it's likely to be expensive I can track down the electrician via the builder. However if it's reasonably cheap it'll be easier to get a local electrician to sort it
Thanks, John
Murdoch
Regular EF Member
Woking
FWIW if the electrician did his "bit" he would have registered the lights with JCC so you would benefit from a 10 year warranty......
Maybe a call to JCC may clear this up?
Murdoch
Regular EF Member
Woking
Midwest
Electrician's Arms
Oxfordshire
Really helpful suggestion - I’ve emailed JCC
Cheers, John
If it is a JCC one, and one of their ill-fated FGLED6, you could probably contact them and get it replaced without it being previously registered for their extended warranty. They had a few, and given up all hope.
Permanent unswitched live colour?
  • Brown
    Votes: 61 67.0%
  • Black
    Votes: 30 33.0%
Electrician Talk
