Discuss No space for new CU. in the UK Electrical Forum area at ElectriciansForums.net
don't matter anyway, coz as soon as you post a pic. on here, it will be turned sideways anyway
Thanks for providing a link back to this thread 1sc , just what we need , a never-ending loop lol.
Thanks for pointing that out although 1) not sure why the forum keeps doing that when I add "speech" tags 2) not sure that it was really worthy of a post. Having said that some like to see those post totals add up eh lmao
;) xxxx
I once got heavily criticised on here when I was a new member, I asked why a cu would not be able to go its side. I got told by a member ( cannot remember who) that an mcb works on gravity. If an mcb is turned on its side then the gravitational pull isn't where it should be and it will affect te trip times.
I then proceeded to say it complete and utter ********
And then got told I didn't have a clue what I was talking about, look into how mcb's are made and come back when ya learnt somat.......
I was always told to mount a CU the correct way up because of the A) IP rating and B) the fact that, if mounted at right angles, it contravenes the manufacturers instructions (not great if anything goes wrong, whether if your fault or not!)
With regards MCBs operating due to gravity, that sounds like rubbish to me... Seen many a board which is DESIGNED for the breakers to be in sideways!
I guess you can, but it isn't worth the hassle, you'll be called back within the week to change it. After the clients know it all neighbour has said "oh that's wrong" " oh that's really dangerous "
I'd either move the isolator, or say to the client it's got to the a smaller board with rcbo's
So long as the client is made aware of what work will be carried out before installation commences and reasons can be supported with the manufacturers instructions/any other literature proving it complies then I'm sure they will be happy and have no reason to be concerned. Sell it to them by showing them the comparison quote of the RCBO's and let them make the decision. :thumbsup
thanks for all the info guys,
Sure you want to know,
It's done,
It's on it's side,
It looks ok,
But...
Won't be doing it again...
And all for the sake of a 17th board with 6 circuits.....!
RCBOs all the way from now on.
guarantee it he posts a pic, thr forum will rotate it 90deg. anyway.
Reply to No space for new CU. in the UK Electrical Forum area at ElectriciansForums.net
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
Doing a kitchen job for my daughter’s music teacher, who also happens to have been in my wife’s class at school. Nothing big… just a little...
Local funeral place is getting a new mortuary fridge unit, and needs some work done. The CU, just for the room, is high up in the corner, just...
Hi all, New homeowner here... hoping it's okay to seek some advice on a quote. I've recently had some wiring done for a new kitchen in a small...
