J
johnst
I live near the coast & have had 2 metallic security lights.
These have each corroded to the extent that the case could not be opened when the light failed.
Can anyone suggest a non metallic security light fitting?
Bulkhead security lights are often made of plastic, and some of the low energy floodlights are plastic.
Generally the halogen floodlights and the LED flood lights need to be able to handle the heat and so are easiest to make of metal.
Some of the low power LED fittings are plastic but then they are not very bright!.
Just buy a LED PIR lamp then there is nothing inside the unit that would need touching!
