B
ben2012
If you have missed a certificate that you were supposed to have submitted online with NIC and so it is now over the 30 days by quiet a bit will you get any kind of come back on it if you just submit it now? or should you re test and submit within date range? thanks
Be never missed the deadline with NIC yet but surely if the works yours issue a new certificate explaining to client why and set an appropriate date. Otherwise you leave client with problems.
and tell customer the guarantee on your work will run from the new certificate date. should keep him sweet.
The notfication police are going to come and knock on your door in the small hours of the morning. You will be "invited" to accompany them to their HQ where you will be interviewed at length possibly under torture, after a summary trial where the verdict is a foregone conclusion you will be sent to Part P camp for "re-education".
You may or may not see your loved ones again.
Or was that just the KGB.
Just to add, this is not a wind up, there are some jobs I still haven't notified for months becaus they aren't finished. Yes I am lazy and haven't filled out the certificate but there it is, it isn't finished!
Its a bit like the earthing and bonding should be upto date before you can change a CU - have you tried getting 1 x 16mm GY and 2 x 10mm GY into those old wyled boards??
notifying building control late?
ben2012,
GLENNSPARK,
