Discuss Old lighting cables in new install in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, newly qualified spark here I went to a job earlier today where the fan was not running on after light had been turned off. Whilst sorting this problem I discovered that the bathroom circuits had been installed on a new rcd db but investigating further in the light and the pull switch the old cables were still in use with the new installed cables. Is this against regs or does it comply if sleeved up? Thanks.
As long as a 2 colour label was stuck on the new consumer unit , then all is good in the world
And yes cores should be sleeved accordingly
Reply to Old lighting cables in new install in the UK Electrical Forum area at ElectriciansForums.net
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
Old two core cable in a lighting circuit with no cpc at any point All points had metal fixtures and fittings class1 At two points the live loop...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
This from a while ago but reading about everyone elses problems tonight made me remember this one. The original job was the lights in a recent...
