Discuss Old three fuse board in the UK Electrical Forum area at ElectriciansForums.net
scribblesvurt
Hello,
Buying a house and found this under the stairs.
http://i.Upload the image directly to the thread.com/fnifwg3.jpg
I'm guessing it needs updating. Am I right in thinking there are three circuits here? What would be involved in getting a new consumer unit. Worth doing?
Also if you cover Wigan let me know.
Thanks for any help.
wigan's just up road from me. good pies in wigan. :p
Well I would suggest getting the important safety work done as a priority first (upgrading the earthing and protective bonding) before doing mainly cosmetic jobs eg a new consumer unit
However since a new consumer unit will have need to address the primary safety feature of earthing and bonding before it be changed,in this instance,yes a new consumer unit would be beneficial
I don't want to appear too old, but I can remember having three fuse Wylexes on the shelf. If you allow me sometime I may be able to recall the part number.
However: I agree, needs updating !
Wylex 304 for a three way Standard board, the first number denotes the number of ways. Add IVY for the ivory coloured one.
I'm not sure I would class the installation of RCDs (commonly referred to as a life saver) as 'cosmetic' work.
Whilst I will conceded that Rcd protection is an additional safety feature and should certainly be considered for older installations that may be being upgraded,reliance on these devices does not compare with the protection afforded by earthing and bonding which was and is the primary safety feature of this installation
The point being trying to be conveyed by me was that the general public tends to see a shiny new board (that may afford little added safety value)as the best safety feature whilst ignoring the most important item
Reply to Old three fuse board in the UK Electrical Forum area at ElectriciansForums.net
Been asked to move, remove and add some sockets the kitchen and I’ll need to add a circuit for an electric hob. Looked at the board and it’s one...
hello all...whats the typical cost for a new consumer unit fitted and the old wired fuse box removed im in a semi detached house in...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Hello, Is there an actual age limit on house wiring that would prevent a traditional fuse box being replaced with a consumer unit please...
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
