S
scribblesvurt
Hello,
Buying a house and found this under the stairs.
http://i.Upload the image directly to the thread.com/fnifwg3.jpg
I'm guessing it needs updating. Am I right in thinking there are three circuits here? What would be involved in getting a new consumer unit. Worth doing?
Also if you cover Wigan let me know.
Thanks for any help.
Get your meter supplier in, doubled up on them tails, and on terminal 3&4.
Reactions: Leesparkykent
wigan's just up road from me. good pies in wigan. :p
Reactions: Spoon
Well Well, never seen a three way wylex.? Always something you have not seen.!
I don't want to appear too old, but I can remember having three fuse Wylexes on the shelf. If you allow me sometime I may be able to recall the part number.
However: I agree, needs updating !
Well I would suggest getting the important safety work done as a priority first (upgrading the earthing and protective bonding) before doing mainly cosmetic jobs eg a new consumer unit
However since a new consumer unit will have need to address the primary safety feature of earthing and bonding before it be changed,in this instance,yes a new consumer unit would be beneficial
Wylex 304 for a three way Standard board, the first number denotes the number of ways. Add IVY for the ivory coloured one.
Reactions: slingshot2000
I'm not sure I would class the installation of RCDs (commonly referred to as a life saver) as 'cosmetic' work.
Whilst I will conceded that Rcd protection is an additional safety feature and should certainly be considered for older installations that may be being upgraded,reliance on these devices does not compare with the protection afforded by earthing and bonding which was and is the primary safety feature of this installation
The point being trying to be conveyed by me was that the general public tends to see a shiny new board (that may afford little added safety value)as the best safety feature whilst ignoring the most important item
Old three fuse board
scribblesvurt,
Des 56,
