L
Lucien Nunes
What is the oldest dimmer switch you have seen in use recently?
When did you install your first dimmer? (Veteran sparks only)
I ask because a friend recently sent me a link to a 'news' story about an old toaster still in use, which I don't even really see as an old toaster (OK, yes, it's older than my daily use toaster but I have much older working toasters.) There are quite a few of these stories around, where people find something from the 1950s still giving service and think that's remarkable. But what about the humble, unobtrusive knob on the wall?
I have one old dimmer still in use at home, it's a 'Crescent 2' 300W model which probably dates from the late 1960s. I haven't been able to pin it down any tighter from the components, but if I trawl some magazines of the era I think there are ads for this specific dimmer. Mounted on MK rounded corner face plates, they use an old circuit based on a stud thyristor inside a bridge rectifier, triggered by a germanium transistor, instead of a triac triggered by a diac which has been standard since the 1970s. This has the disadvantage of two extra diode-drops so higher heat dissipation, but the advantage of absolute firing symmetry. I see flicker very easily and can spot a diac-triggered triac dimmer that has a 50Hz component in its output due to slightly different triggering voltages on the two half-waves.
We had five of these at one time, some were retired with the coming of the CFL, another replaced with an IR remote-controlled one, etc. One did fail with a leaky AC128. The last one is likely to get retired soon as I want to try LED in this fitting that is on for many hours a day and will need a compatible dimmer. At the moment the Crescent 2 is dimming a 150W GLS lamp, it has had up to 200W (often 2x 100W in a bayonet Y-adaptor) as it's a key light source in the lounge. The main reason the Crescent has survived so long is the high quality Allen-Bradley pots they used, which never seem to wear out.
Let's see your old dimmers. I have a soft spot for the edge-thumbwheel-controlled MKs of the 70s-80s with the separate switch. I don't think we have any in the collection though.
Could never really see the point in why you'd want to have more than one light in the same room switched together with one dimming and the other/s staying at full wallop ?
