O
overskilled
So went to look at a non working light fitting today in a house thats being sold, 2 way switching in small bedroom, otherswitch hidden behind wardrobe and jammed between on and off...
speaking to the seller, last owner was an old lady and there had been a bed beside the second switch when he had moved in...
mentioned the age of the install to him and that it was 3 phase, he then remarked that another local spark had told him it wasn't possible to upgrade the fuseboxes due to the 3phase....baulked at the work involved more like...
mish mash of solid core and stranded core PVC T+E, apart from the bundle of cables to the right of the rather ancient looking black switchfuse...looked fabric covered and I wouldn't have excluded the possibility of them being VIR......
Left some cards...so perhaps the new owner might be interested in getting this lot upgraded....
A few photos included...old3phaseinstall001.jpgold3phaseinstall002.jpgold3phaseinstall003.jpgold3phaseinstall004.jpg
(I noticed the missing MCB on the RHS of pic 2, but owner not interested in sorting as he was moving anyway)
yep look like old braided VIR tails to the switch fuse , how can the DNO get away with installing the incomming tails like that with only basic insulation we'd get it if we did it like that
Upvote 0
its an utter mish mash....vir, imperial T+E, metric T+E, digital (!!!) 2 rate meter (house now on gas)
Frankly...it might be quicker and cheaper in labour terms to rip the lot out and startover from the meter onwards....
Upvote 0
That memrex senior switchfuse...anyone know if it contains asbestos?
As if I remember correctly the newer MEM Exel (to the right of the meter) does....
Upvote 0
They contain so little asbestos as to not make them worth bothering about. If you’re that bothered about it, pull the fuse and spray the braid with glue.
Upvote 0
Where is that DNO cable coming from, ...is this a PME'd overhead supply?? Can't make out what that DNO supply cable is either?? ...For some reason i can't blow it up to get a closer look!!
Upvote 0
Same here, where are the DNO fuses.... and what is that earth doing?
It's not the worst I've seen, by any means, after the incomer. Seen a lot more untidy set ups.
Before anyone buys the place it should be a full test...but then again, who knows ?
edit. I like the tape labelling on the doorframe:D
Upvote 0
Might have been overhead originally, house dates from turn of century and originally was in village that's now part of the town. Didn't get much chance to poke around as I was just there to fix the light....I have bigger versions wasn't sure what the forum max was so went with 1200 wide
Upvote 0
3 bakelite blocks methinks are the dno fuses, seen sp heads similar, last place was built in 1969 and had sp dno fuse the same...
Upvote 0
