Discuss Options for ceiling light via socket in the UK Electrical Forum area at ElectriciansForums.net
Dobbin211
Hi,
Hoping for some guidance please. I am undertaking a 3/4 garage conversion as a DIY project. It’s not to building regs and is intended as a ‘remove it if ever sell’ situation.
The garage has existing power outlet - it’s a double socket on a ring main (not a spur). The issue I have is the socket is the ‘wrong’ side. I know I should not mess with electrics and cause any undue risk and wish to comply with Part P. So
I am looking for a temporary solution without buried wires and everything I do all coming from plugs in the existing double socket - i.e. no new wiring.
I plan on running a 10m extension lead through the new stud wall and into the ‘usable room’ of the garage. I can plug a small load through this so I think power wise, I am ok.
What I am struggling with is lighting. I really want a ceiling light with ‘switch’ like a usual room. I believe I can get a ceiling light and wire this to a plug with a 3amp fuse (please tell me if you think otherwise). What I ideally want is a switch in the middle of that on the wall. I.e. a plug in the double socket runs through new stud wall to a switch on the wall and then to a ceiling light.
Is this possible without contrevening Part P and adding and risk factor? What would be my best option here?
Many thanks in advance,
Sean
Reply to Options for ceiling light via socket in the UK Electrical Forum area at ElectriciansForums.net
Hi, just helping someone out and apologies for the long winded post. Would like install a couple of weatherproof double sockets on the patio. 1...
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
Hi. I'm in the process of getting my qualifications and am taking on some small jobs for family to try and get some experience in. Today I was...
I live in a warehouse condo, converted about 20 years ago. The building dates to about 1870 but with the conversion, all of the electrical was...
