Discuss Out side light not working. in the The Welcome Forum area at ElectriciansForums.net
N
Nigel7347
Hi I was wondering if someone could please help. I have an external light which is not working even when a new bulb is but in the unit.
Any suggestions please?
Thanks for reply but when I try to view it I can see the reply is covered by an advert. I can not see how to delete or close the advert.
External lights are often fed from a fused connection unit somewhere - see if you can locate one and try changing the fuse in it, like for like, with a known working one.
Thanks for your reply.
I have circuit breakers which all seem fine but I do not think there are any fuses or if there are I do not know where they are.
The switch itself seems ok because there are 2 outside lights all together and the switch works one but not the other light.
I was hoping the lamp took the circuit breaker with it, so a new lamp and a reset would fix it. But it now sounds like a fault, likely loose wiring somewhere. So you might be best served to get a local Electrician in to have a quick look? Lots on here :)
nigel, warrington is on my patch. be happy to call and fix for a sensible cal-out charge.
Reply to Out side light not working. in the The Welcome Forum area at ElectriciansForums.net
My kitchen has track lighting. It consists of three halogen light bulbs. I've had the fixture for more than 25 years with no issues. Last night...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
Hi All, Would be grateful for some advice. Would like to add an additional light (Undercabinet 8W LED Batten light) to a two-way light switch...
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
