R
RB94
Hi
I wonder if anybody could advise me.
At present we have an outdoor consumer unit which is fed from an outlet for in the kitchen for the cooker. The consumer unit powers a Jacuzzi and a plug socket in the shed. My question is, how much power can I pull off this unit at one time?
Let me know if you need more information.
Hi
A dam sight more information than you have given so far!!
I'd get some more info and at least one photo up here sharpish. You'll get a much better response. :-) Daz
Hi
It sounds to me as if your current installation is using a cooker circuit as a sub-main, which in itself is not an issue if there is no cooker attached and the cable sizing and the circuit protection is up to standard, however giving you information to take this further is fraught with issues because, with respect, you are unlikely to understand the issues surrounding volt drop, correct cable sizing, correct disconnection times and correct circuit protection requirements. I would suggest you contact a local spark, possibly one of the Guys from this forum, and not only have the Job fully inspected and appraised professionally, but you will also receive accurate and in-depth information, but an accurate quotation for any works that either need to be done or which you would like to be done.
keep adding load till you either smell burning or the fuse/MCB pops. then back off.
all the poles use that method. sod buying test gear.
So, your best option is to post your location and get a spark round. I'm assuming you are not a spark!
Here he goes again, with these sensible thought out replies.
It's Friday, get your laughing gear round some booze!!!
ahh, just in from work, and log into forum, only to be greeted with another bloody 'outdoor power' thread!
I really ought to just specialise in doing said installs as it seems there is a massive demand for them.
RB94- given that the current setup is powering a jacuzzi, I am going to assume you have a few pennies to your name. Spend em wisely, and get an electrician from this forum to come and take a look for you.
as for how much can it handle at once, why do you ask. what is it you plan to/ want to power at once?
also, as Daz said, at least one decent photo would help you here.
I hope the outdoor consumer unit has suitable characterstics....sorry OP just from the original post, i have a vision that you've got a board stuck on ure outside wall under the window freezing it's nads off because it's IP rating is on par with leeds united.
Obviouslly won't be the case, fingers crossed lol, more information Sir ..... and depending on what time this info arrives, will determine the answer you recieve. 99% off the forum will be cracking open the tins in under an hour lol.
