Surprised because even SWA sheath is PVC isn't it, although T&E not recommended outside could make a interesting test just leave some in a bucket and take measurements now and then.
Had some old White T&E outside for ages although partly sheltered.
most SWA used these days is XLPE. (polyethylene) as well as having a higher heat rating, it's water resistance is better than PVC.
The sheath of most general swa cables is pvc it is the conductor insulation which is xlpe.
My guess is the black flex came on the light and the grey box is a socket.
the sparks has possibly just whacked a 13a plugtop on the end of the flex and plugged it in.
not the worst idea in the world as the next guy can easily swap the light if it stops working.
as for flex outside I don’t have an issue with it, could have dressed it straight straight up with 2 clips thou..
I stand corrected. :(
stiil the sheath must have good water ingress protection when buried in damp soil for years without any penetration. any time water gets in, it's usually at the glands ( or if a bodge job, where it's not even glanded).
Pvc is water resistant but swa cables from memory when working at a marina are not recommended for being submerged in water. This thread popped up yesterday.
The worst I've had is CCTV cable that was some kind of Black Flex melt.
and the old White T&E cracking in the sun but that stuff seems tuffer to me but maybe that's for another thread....
