Discuss Paint covered cables - further derate or not? in the UK Electrical Forum area at ElectriciansForums.net
Rockingit
Mentor
Supporter
So I spotted this earlier (venue in Holland) and it got me thinking, be interested to hear people’s thoughts. Painting over cables surely has to effect their thermal dissipation from manufacturers design, so do we apply a further derate, and if so based on what values?
There are two opposing effects at work here - radial thickness and surface area, neither of them probably very significant. The additional thickness of the paint layer adds thermal insulation between the conductor and air; I don't have data but would not be surprised if the thermal resistance of the paint is relatively similar to the sheath material. Since it is applied as a liquid there should not be any significant voids between sheath and paint to create an extra boundary layer.
But the addition of the paint also increases the overall diameter and hence the surface area, the latter more so if the paint surface is less smooth than the sheath. Since a significant part of the thermal resistance from conductor to ambient comes from the interface to the air, it is quite possible that the two effects cancel partially or completely, or even that the additional surface area improves the heat dissipation.
Makes perfect sense to me.
Reply to Paint covered cables - further derate or not? in the UK Electrical Forum area at ElectriciansForums.net
Hey, I lifted a few sockets from a wall so I could paint without having to cut in around them. I haven’t lifted any light switches yet. When...
Hi all, I am an electrician working for a OEM machinery manufacturer based in Germany, we are the local hub that is now taking over the...
  • Locked
5K
This is quite lengthy so get comfy... I had a bizarre call out relating to a job I attended about five years ago. The situation was they were...
In show world we use 19c 'socapex' cable as a staple, standard cable for connecting lighting dimmers to lights via 19 pin screwed connectors and...
