Discuss panel board / metering advice in the Australia area at ElectriciansForums.net
H
hodaire
looking at a rewire for a block of 8 apartments, have a 3 phase supply in the basement, been asked to provide seperate metering next to the supply authorities meter.
be running an swa (not sure of size but possibly for 63amp single phase supply) to cu in each apartment
maybe also need to install a 3 phase board in the basement
can anyone suggest a fairly simple (easiest) way of providing this, are there any panel boards with meters already mounted etc...
apprieciate any help you can offer
Hi there and welcome to the forums.
I usually use the Merlin Gerin metering equipment myself, can be a bit more expensive though. Dorman Smith also do a good metering pack for their panel boards.
With the Merlin kit you can direct connect loads upto 63A, anything more and you would need CT metering
Can I ask why they require additional metering to the suppliers meter??
Cheers.
P.S link below.
http://www.schneider-electric.co.uk/electricity.nsf/results?open&query=meters
supplier will only be putting the 1 meter in, need to supply meters / panel board so the landlord can split the bill
just looking for something fairly easy / tidy to install,
If you dont want to go down the metered panelboard route then you can buy recon electricity meters from the wholesaler for about £12.
I maintain a few block flats for a housing association. There set up is as follows.
3 phase supply and meter from DNO is fed into a switch fuse then into a busbar chamber. From there tails are taken to a individual switch fuse for each flat and metered via a CT.
Simple but effective,
Ian
Reply to panel board / metering advice in the Australia area at ElectriciansForums.net
Morning all, Really hoping to get some advice / confirm what a few of us are thinking about a job in the future. Back ground - We have to swap...
What are peoples opinion's on this, pair of big old semi-detached houses (85 and 87) converted into apartments, dont think its a HMO although it...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
hi guys / girls , any advice would be appreciated, So the situation is a domestic property has a 3 phase supply , from the service head we have 3...
