Despite the downsides I pointed out in earlier posts I think the OP should at least give it a try.
There are skills to be learnt without a doubt, and it will be interesting (at least at first) as all new things are.
It depends on the panel builder as to how much variety you get.
I was just pointing out the fact that it is not for everybody, or rather does not suit everybody, and I would be doing the OP a disservice if I did not point out the potential downsides and the reality of this type of work.
I tried to paint a fairly accurate description and truly did not mean to sound so negative.
go for it
its good training and experience
but document everything and if you think you have enough copies of the documentation always make a couple more copies you will thank yourself later
As has been stated by others, it's an opportunity to learn new skills as well as understanding how things come together. It's not a life sentence, you can come out of this position whenever you choose, and put those new skills to good use for yourself!!
Go for it,it,s a chance to learn something new and from experience I know where I,d rather be in a cold wet winter.
I would agree, go for it. Even if you find that, after say 6 months, you have had enough you are very likely to have gained knowledge on how panels are put together which could be very useful in other work. E.g. building maintenance which could easily involve working on and fault finding control panels.
Hi All
I have been given the chance to train to wire up electrical panels and learn to properly read drawings that are used by the railways.This is a big step for me as have only worked doing bashing over the years would this be a good move ,it is a permanent job not contract for a local firm who have been wiring panels for years
Rich
One more vote for do it!
Get copies of every drawing, study them and work out how everything works.
Follow the numbers to begin with, then progress to understand how it all works when you're building them.
Great opportunity to learn and progress.
Any opportunity anyone gets to learn something new, especially being paid for it, grab it with both hands!!!
thank you every one for the honest comments I am going to see the boss of the firm and will report back what the job involves
Rich
