Discuss Part 1 : Skilled Tradesman?? in the UK Electrical Forum area at ElectriciansForums.net
ok guys here's the story........building lost power due to break in main supply cable, electricity board decided its easier to move headers (3 phase and single phase) to new location by cutting and re-routing main supply cables.
joint completed
Now.....
all that is needed is 4 new supply cables to be run around the premises (seperate buildings) to each CCU location, i have refused to have any involvement with this work as its a big c###up from the start.
temporary supply is provided by 10mm T&E run all over the place.....
so said "tradesman" has stepped up saying he has worked out the volt drops to each CCU and 3 core 35mm SWA is needed for 3 locations and 70mm SWA for one..........or in this case 2 35mm's run in parallel!!!
so he runs all cables to CCU locations and TRIES to terminate 4 35mm SWA's into.......
nice busbar!!!
and a single 35mm into.....
having now realised this isnt 'big enough' he orders a metal 3 phase board, NO BREAKERS, and well, heres the pics..........
sponsored by theWildWest.com!!!!!
eh?...
lol...lol...lol...
Reply to Part 1 : Skilled Tradesman?? in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, On a job at the moment and trying to Work out cable size needed for property supply. Lots going on and struggle to work out...
I have been asked to provide a quote for a supply to an toilet block on a campsite. The three phase supply to the campsite is approx. 150m from...
Hi, just looking for advice. Ive been to look at a Fire alarm install job. While checking where i will take my supply from. 3 phase sub board, i...
Hi all, Hope you're keeping well I'm currently wiring a small commercial premises. 3 phas incoming supply, 16sq cables As it is in an urban...
Does a SPD need a dedicated way? I need an extra way in this unit for a 3 phase car charger As you can see its a small unit with no extra...
