C
cjks
hi guys, can someone shed some light on how to sketch phase displacement on voltages please as this is the question and its baffling me
'with the aid of a small diagram show the phase displacement of voltages for a 415/240 and neutral for a small unit.'
many thanks
Well the phases are 120 degrees apart (360/3) if that helps. Not sure I should just tell you how to do your homework though.
just enter " sketch phase displacement on voltages" in your search engine and then once loaded click on images
Meerkat says "Simples" really
Look HERE
The two main types are Dyn11 and Dyn1, but you can look for them with the link and you'll see the diference in angles.
Funny this should crop up I'm just doing a drawing of a tranformer 24 phase!
i understand that they are 120 degrees apart but im not very imaginative and cannot for the life of me think how to 'sketch' this
Be carefull the question could be phase angles or phase shift. Phase shift is the relationship between HV/LV
