Discuss phase displacement of voltages in the UK Electrical Forum area at ElectriciansForums.net
C
cjks
hi guys, can someone shed some light on how to sketch phase displacement on voltages please as this is the question and its baffling me
'with the aid of a small diagram show the phase displacement of voltages for a 415/240 and neutral for a small unit.'
many thanks
just enter " sketch phase displacement on voltages" in your search engine and then once loaded click on images
Meerkat says "Simples" really
Look HERE
The two main types are Dyn11 and Dyn1, but you can look for them with the link and you'll see the diference in angles.
Funny this should crop up I'm just doing a drawing of a tranformer 24 phase!
i understand that they are 120 degrees apart but im not very imaginative and cannot for the life of me think how to 'sketch' this
Reply to phase displacement of voltages in the UK Electrical Forum area at ElectriciansForums.net
Hi, I am looking for a connection diagram or sugestions for a 2.2Kw single phase motor to drive a compressor. The spec plate shows that it can be...
Hi all.. Bit of a nightmare afternoon,, testing a caravan park TP&N panel board IR testing while board isolated before returning power (merlin...
Hello, I have a hypothetical question (I'm an electrical engineer) to better understand RCBOs and how they are used in the USA. Let's say I would...
I have a 3 phase element for a steam generator but the element is a 220 volt element. the diagram is in Chinese which i cant read. on the diagram...
