Discuss pir lighting in the Australia area at ElectriciansForums.net
B
blenki
Hi , when having 2 lights with integral pir,isthe wiring connections the same as having external pirs, im going to have 2 integral pir lights and i need to wire them so that either sensor turns both lights on,i assume il need 3 core and earth.
As markspark says..the third core is the common linked switchwire.......
One thing to bear in mind if these are to be the 500watt type of halogen fitting , then they will both be operating at the same time consuming a current of approx 4 A....if they are wired from a lighting circuit [as opposed to their own circuit or via a spur off the ring], then you will need to assess the expected loading of the remainder of the circuit, especially if you have multi-lamp type internal fittings or many 50w. downlights etc
spark1
Reply to pir lighting in the Australia area at ElectriciansForums.net
Hi, Heavy industrial spark here, never do house bashing hence the question. I currently have a light switch at the front door not doing anything...
Hi there, I have an outside light that is turned on with a switch from inside and would like to change it to a PIR version incorporating an...
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
I have a Security Light on my patio and until recently it worked fine. It stopped working and I couldn't decide if it was the LED Floodlight or...
