Discuss Plastering directly over T&E in the UK Electrical Forum area at ElectriciansForums.net
yep i am jumping the gun. i always worry about future problems !!!
Being prepared is one thing but giving your attention to other areas of concern whilst carrying out electrical installation will catch you out. Electrics is all about working methodically so once you have proven continuity and IR THEN you can think about plaster. If you are going to cap cables then the testing will need to occur after this because it is possible to nip a cable in the process. If plastering direct then you will still need to use cable clips on the cable to secure them to the wall. If you do not do this then the cables will keep bouncing off the wall and probably end up being visible after you have plastered.
One thing I would add is, get that ****ing sparky in to help/advise you appropriately. Regardless of what you are paying him for his services he will be responsible for the entire installation of the circuit/s if he is signing it off!
Ted, if you are ready to plaster than I am presuming that all the cables are in? This would be an ideal time to get the first fix tested for continuity and an insulation resistance test carried out.
This is where wago connectors work a treat:thumbsup
Testing before 2nd fix eh? That's a new one. Total and utter waste of time IMO
So now we know who tedglen really is. Do you honestly think you should be helping sparkies out at 92 years old Phil?
Put your feet up man just like you've done since the end of the war:)
Murdoch, there is no need to be a cocky **** now is there ?
There is absolutely no need for such a response like that. Your sequence of posts has consistently suggested that you have an electrician on the job but I'd venture to suggest thats not true.
For the record I'm not being cocky. This is the electricians forum for professional electricians who pay sums to be registered, insured, have the relevent qualifications, experience and tools - which you seem intent on abusing. Its not the B&Q or Wickes forum.
I do not like you attitude. I have electrician on board but I was concerned when I read somewhere that plaster affects cable. I was trusting your opinions more than an one electrician who may or may not be a cowboy
There's another reason for capping, not electric but will help the plastering finish. When simply plastering over cable you can leave gaps, hairline gaps which can become cracks or weak points in the plastering.
doesnt apply to dot and dab obviously.
Really?
So you trust that once you've completed your first fix everything is spot on? How do you know that? Do you not make mistakes?
I ALWAYS test for continuity/IR on the circuits I have installed on completion of first fix so that I know 100% when I return any faults have been caused by kitchen fitters or additional works that have taken place since first fix completion.
The use of wago lever connectors make this an absolute doddle and for how long the test take I think it's worth it's weight in gold.
Inspection and testing should be performed before, during and after installation to ensure that the integrity of the circuit has not been compromised. If you're not doing it then it may well come back and bite you on the behind when the client refuses to pay for repair works required that may require ripping out cable that has since been tiled over, plastered or even had kitchen cabinets installed in front of runs.
Complete waste of time? My backside it is but hey... I'm just a Electrical Trainee so what do I know??? lol
In a domestic situation I class first fix as cables in, boxes sunk and fixed and capping. Second fix is accessories on, it's at this point that the testing regime kicks in for me. I appreciate your point but I think your method is a waste of time. Each to their own though, it's always interesting to get another's point of view
I have to admit,if I stripped a cable to test it,I would be too tempted to shove the front on,the second fix would be done before the plasterer had got his trowel out
Can't fault anyone doing things to the book,it just isn't me
By the way Ted,whats with insulting Murdoch,a well respected member ?
Testing after first fix is pointless to an extent, when cables are installed you should be confident that all is good. Its after first fix and before second fix that things go wrong, plasterers damage cables, etc etc. So agree with trev above
To an extent I totally agree because results I have recorded have always been satisfactory. However, anyone can be confident that the work they complete is all good but having test results confirm this secures that confidence and provides you with proof should any damage occur at a later date.
I guess it depends at what point second fix is completed? The second fixes I have done have always been completed after plastering, tiling and kitchen units have been fixed and as mentioned this is where the damage can be caused :thumbsup
Reply to Plastering directly over T&E in the UK Electrical Forum area at ElectriciansForums.net
I have had my kitchen rewired and plastered. I have had a 6mm t+e on a dedicated 32a circuit for a 60cm electric cooker. In hindsight, had i known...
Essentially I have a "normal" socket in a ring mains, i.e. one 2.5mm T&E going in and one 2.5mm T&E going out. I am looking to simply add two more...
Seen a couple of videos with Doncaster cables now producuing a T&E with the CPC already sleeved so no need to fit our own. I also read somewhere...
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
Client has had a meter installed for a new consumer unit in their shop they are looking to rent out the spare space for a barber shop so they want...
