Discuss Plastic consumer units and how to code them in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
A domestic installer is a term developed by governing bodies like NICEIC, and means Jack Poo when it comes to experience and qualifications. A company can be registered has an Approved Contractor, and under that umbrella send a young lad 1 year into his apprenticeship to cover work way out of his league. And before you say that shouldn't happen, we all know that, but real world it does. And often. If someone qualifies as an electrician but works on domestic installs all his life, then I call that a domestic electrician. But a fully qualified electrician, really needs to have commercial as well as domestic work under there belt. Part P has done no favours in this field, because you now have defined scope Domestic Installers which is ridiculous. The JIB have a better idea, grading a sparks on qualifications and ability. Not fool proof granted. But an NICEIC Approved contractor would mean nothing to me if I were for example a facilities manager. I would want to know what experience and quals the operative on the tools had before letting them loose on my electrics.
In order to qualify they must do exactly that. It may be that the required level of understanding is less than ideal, or less than you might like, but nonetheless those requirements are in place.
I guess it depends on what you mean by electrical principles.
To me that means things like Ohm's Law, why cables have to be certain sizes, why installation methods matter, the characteristics of OPDs, what bonding does and why and how it is not earthing, the nature of different supply types....
Not "the blue one goes here and the brown one there".
Experience is a factor in anything and everything, no matter how rigorous and comprehensive the qualifications-related training.
But regarding qualifications..
To register as a Domestic Installer two qualifications are generally required:
  1. Current Level 3 Award in the Requirements for Electrical Installations (17th Edition), and either
  2. Level 3 Award in the Initial Verification and Certification of Electrical Installations, or
  3. Level 3 Award in Approving Electrical Work in Dwellings in Compliance with Building Regulations.
These qualifications can be achieved relatively quickly with a recommended learning period of around 100 hours in total. That could be as little as 3 weeks depending on centre requirements and prior experience.
As I said - DI status can be easily obtained by anyone who can demonstrate a very basic level of ability.
Surely domestic installers are taught those very subjects?
Don't get me wrong; I'm not in favour of the whole domestic installer idea, but I'd imagine everything covered in your sentence to be central to their training.
Not "the blue one goes here and the brown one there" But if they know where the black and red ones go that could be an indication of experience, ? Very loosely, and tongue in cheek of course. ?
And yet we were recently treated to the spectacle here of someone with 2391 who, when told that a cable was undersized for the breaker he wanted to put it on, thought that the answer was an even higher rated breaker.
I wonder when he was required to demonstrate anything more than a very basic level of understanding?
And where are the topics I mentioned made central to the syllabi for 2382, 2391, or 2397?
I read that post, but using it as an example hardly addresses the question I asked. Are domestic installers taught basic electrical principles or not?
If we are to judge the abilities of every domestic installer on the basis of a question asked by one individual, we'd similarly have to jump to the idiotic conclusion that all electricians are bumbling fools on the basis of shoddy work carried out by any one individual. We're all adults here, so let's discuss this accordingly and not resort to hyperbole to avoid clarifying previous comments.
Yes a rounded out apprenticeship should include both. Ironically I have always found domestic work to be more challenging (and more educational) than commercial work. Faultfinding skills tend to be honed in the domestic rather than the commercial field as offices etc rarely require more than lights, sockets and data. Whereas a modern house will have a much greater variety of electrical accessories be it showers, storage heating, solar panel heating, electric gates, heat pumps etc.
A house rewire for instance requires skills and experience not required in commercial work.
Which just goes to show that quals alone can often be deceiving. If you have a good memory and pick something up parrot fashion you can scrape through with little concept or understanding of the practical implications. I have known some very qualified individuals, with lots of bits of paper, turn out to be a complete waste of time when it comes to truly understanding the concept behind designing, and the ifs what's and whys of why something is done, the way it is. Having said that, provided you DO understand what your doing. The 2391 isn't a bad qual as quals go. I remember doing the 236. Started as UEI 1&2 for the first couple of years. The 3rd year was part B. But then the C cert took me another two years of evening work. A lot of mates called it a day after the B. And I can understand why really, as a younger lad I lost out on a lot of overtime when earning the extra crust was needed. So those two evenings a week for the C, ended up costing me in other ways. But it was my apprenticeship and the people who mentored me, combined with the exam courses that really help you get to gaining experience.
All true - one example does not make it typical.
I don't think so.
Having been involved in NHS installs, Supermarkets, Garages, Data centres and the likes, as well as domestic, (although getting a bit too old for house bashing these days). I can assure you the complexities within commercial and industrial far exceed anything found in the domestic field. Both have there own disciplines and are constantly evolving. But to say commercial installs only involve lights sockets and data, would suggest a limited input. What about Composite panel install vs a consumer unit. No comparison to be fair. Or Generator and UPS installs in large data centres, mechanical heating and ventilation systems, again no comparison, Garage forecourts and the obvious hazards therein regarding such installs. The list goes on. Even a Supermarket has considerable installation work, way above and beyond that of the average home.
Yes House wiring should always be completed by someone with the right skill set, but I know for a fact, that someone who has only ever dealt with house rewires would be completely out of there depth in the commercial world if involved with all aspects of an installation therein. The reverse however is very different, although there are tips and tricks a commercial sparks would need to learn, it certainly wont take as long to pick up as the reverse. A commercial background gives you a wealth of skill sets, and always will.
This seems to be the crux of our issue.
You assume they aren't taught these basic principles and I assume they are. On that basis it would appear that we are both fools, regardless of what the actual facts are.
When you look at the qualifications required to be deemed a "Domestic Installer", and the topics they cover, there are none which include basic physics.
I did, nt mean to suggest that commercial installations were, nt sophisticated. In practice any project that is commercial or industrial comes complete with project management and drawings. Every "T" is crossed and every "i" is dotted. Basically we follow the drawings. Usually On a domestic project the management rests with the the electrical contractor himself who will liase directly with the client. Any issues that arise must be dealt with by the contractor. I, ve found that aspect of domestic work to be educational.
Having been involved in NHS installs, Supermarkets, Garages, Data centres and the likes, as well as domestic, I can assure you the complexities within commercial and industrial far exceed anything found in the domestic field.
Your post came to mind last night. I was involved in faultfinding a SHEV system for a UK property company in a local supermarket. And as you state above, much more complex than domestic faultfinding.
I could have explained myself a little better there. I served my time with a small domestic contractor. But in practice, small contractors have a finger in every pie, only have themselves to rely on and want to extract as much benefit from their apprentices as possible. So there is great experience from the getgo. I had a very varied apprenticeship. When I qualified and wanted a bit of adventure in the industrial world I spent a few years working on refineries, ships, oil rigs, generating stations, you name it. I could summarise it all in by describing it as a very long line of tray, Trunking, conduit, swa and numbered cable terminations. We called ourselves "unistrut engineers". I love Installation work. Good fun but if you were, nt part of the commission team, it was, nt technically demanding.
Today I am working again as a domestic contractor with a "finger in every pie". Last night I had an extremely demanding (but rewarding) "technical" experience. It was that idea that I was originally trying to convey in my earlier post.
By the way, you mentioned that you comlpeted your C&G course. I know of very few apprentices who did that. Respect!
At the end of the 3 years, and having achieved the 236 B. A lot of companies felt you were sufficiently qualified to get out there and start earning them some money.
I did feel it was very much down to me when it came to the C cert which was considered a technical grade. I still feel the 236 although old (like me) was a well rounded qualification that when completed with an apprenticeship gave those in the trade a good start to there electrical career. These days there are to many quick fix courses with little substance and giving rise to a lot of confusion as to just how competent operatives are once they have them. Recognised and standardised quality courses, with decent tuition and multiple years to complete, combined with proper apprenticeships is the only way to achieve the right foundation towards being truly qualified. For this reason I feel quick fix wonder courses degrade our trade and are nothing short of bloody dangerous. But Im an old fart so what do I know. ??
As I mentioned, served my time with a small domestic contractor. The downside was the technical training provided. Seen as the "poorer relation", domestic contractors were obliged to send their apprentices to technical college 1 day a week only. Apprentices with bigger contractors got a 3 month block release course every year. There was a significant gap in technical training provided. As you say "it was down to me" to invest the time in keeping up with the rest which is what I did. Nightschool and personal input were required. All worth it in the end though.
Course C was on my agenda but just had too many balls to juggle at the time and it (unfortunately) never happened
I wonder how long it will be before this goes even further and we have metal MCB's, RCD's, RCBO's and main switch's, even to the extent of T&E being metal sheathed, or maybe back to metal conduit becoming compulsory.
That’s actually a good shout conduit rarely used these days & the relevant problems not using this, is causing many a problem now.
Who would ever think now, clipping T&E with metallic clips…
Reply to Plastic consumer units and how to code them in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi all, Been asked to do EICR on thatched property for insurance purposes, however they will want all C3 codes rectified. Haven't seen it yet but...
Hi, NAPIT report was carried out due to flood, all kitchen appliances, wall/light switches, fire/heaters etc need replacing. The electrician...
Another thread asked about two circuits sharing a common multi-core cable and regulation 521.8.1 was mentioned. A friend of mine has inherited...
Hello engineers. I did EICR in two bed rented flat in a block of flats. There is old plastic fuseboard just above the entry door. There are only...
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
