Discuss Pliable Conduit? in the UK Electrical Forum area at ElectriciansForums.net
I think its that flexible type conduit that can bend very easily. Looks a bit like a vacuum cleaner hose but much smaller. As i said.. "I think" :)
pliable relates to all plastic conduit as well as flexible. in as much as it will bend. whereas steel is rigid.
Flexible pipe - bends and flaps around with no effort.
Pliable corrugated metal pipe - can be bent by hand and retains its shape.
Rigid metal or plastic pipe - requires forming in some way.
Reply to Pliable Conduit? in the UK Electrical Forum area at ElectriciansForums.net
I don't think I have worked with 32mm conduit before. Always 25mm and 20mm. I want to contain 2 x 25mm tails and 1 x 16mm earth in some 32mm...
I was looking for the likes of the SQB1603K and see it is out of stock at CEF and no delivery option available. Odd. Then I search for the part on...
I've an otherwise small and simple job to do later, out of hours, fit an outdoor IP FSU for a small AC unit fed from an outdoor socket on an RFC...
Hi there, I'm Currently doing my design calcs for my college project and doing the actual Zs calculation. Formula is Zs= Ze (or Zdb) + (R1+R2)...
I have a bathroom fan with a moisture detector that turns it on and off. It also has a control circuit to turn it on/off when moisture is not...
