G
Guitarist
Seen a few outbuildings over the years run to the house in armoured, terminated into an adaptable box near a socket, then flex out to a plug.
Massive extension lead or fixed wiring with isolating plug? :6:
If done properly with the right csa cable, pd, etc I'd suppose it would be fixed wiring. Saw a good one at an old ladies house once, she had an outside light connected into a single s/o which wasn't connected to the RFC, to power it she had a length of flex with a plug top at both ends. The installer must have been a real credit to our profession:)
I remember seeing something similar as a kid back in the early 80's. My friend had a shed with a metalclad double socket so he could use power tools for his school woodworking projects. It was connected with a plug going into one of the socket outlets in the shed, then was plugged in to the house. Occasionally he would plug it in at the house first by mistake, then had to be very careful how he plugged it into the shed!!! :dizzy2:
No RCD's back then.
I first picked up a guitar at 8 years old and got pretty good at repairs and maintenance of them by the time I hit comprehensive school. A lad there wanted to amplify his shiny new axe which was his first, he asked me if he could achieve Marshall type sound levels by fitting a plug on to one end of a jack lead.
Obviously I told him this was not a good idea
No RCD's back then.
Ahhhhhhhhhh the old widow maker extension lead, not seen one of those for years
Used to see (and use:6:) them on new build housing sites years ago.
The show home would always be the first to be completed with it's mains supply connected so used then to run temp power to other plots that didn't have final connection to the main supply yet. As Malc said, they were known as widow makers!!
Reminds me of when we moved into our current house. Plug top run from a spur on the RFC with 1.0mm T&E fed through some garden hose and buried, 20m run to the garage where it terminated in a 4G socket extension.
I think my exact words were 'sweet baby Jesus and all the ****ing orphans'.
A friend of mine has a story involving a plug top to plug top lead. I'm not sure of the details but the jist of it goes like this. Working under an isolated static caravan, cleaner comes along with modified lead, links live caravan to isolated one so she can hoover it, mate gets almighty crack, all hell gets played up down the site office.
Scary stuff
So, on a test form you could add the note "No equipment tested which is connected via plug and socket".....
IMO it's more of a '*******ised abomination'. If it's got a plug on it does it need to be PAT tested? I suppose you could try arguing that unless the shed is on wheels it isn't a 'Portable' appliance so it doesn't need any testing at all.
