Discuss Positioning a consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Hi all,
Quick question, I will be putting a small consumer unit in a garage which has accommodation upstairs, I was going to put the CU in an eaves cupboard so it is accessible but not in the main room, however, does it have to conform to the regs regarding heights of switches (450 - 1200mm)? Bearing in mind the accommodation is up some steep outside stairs so wheelchair access will not be possible.
Thanks for any help
D2E
If it's a new build...yes it will need to conform with building regs....otherwise no,but use common sense with positioning.....a common mistake with a garage is no allowing for up and over doors when positioning a CU
(Didnt get yer legover this morning i=p/u ?.....:laugh3:)
Reply to Positioning a consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Hi All, looking for some assistance on this as finding different information wherever i look. We have a garage external to the house, which we...
4K
Currently I have a Henley block which has 2 consumer units. 1 of these CU feeds a garden supply and garage. Out in the garden which is fed by a...
I was asked to see why a set of sockets weren’t working in the house (which appear to be a ring circuit based on breakers) There was no power on...
Hi, I'm interested in a house built around the 1980's in Northern Ireland. I took a few photos of the consumer unit etc. which is situated in the...
C
Hello, I recently bought and moved into my first home, and I made an enquiry with an electrician about doing a like for like swap of electric...
coalminers crufties
C
