Discuss Power to shed. Thoughts? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Looked at that and the cupboards at the top are full length and go right to the ceiling, look custom made so no sneaky void hiding up top by the looks of things sadly!
Well there is some sort of extra wood fastened to the face of those cabinets
I with @Leesparkykent, fish it under the plinths and through the wall. Solid board cutter route will be just as good, there are blanks specifically designed for the cut out. Export the TNCS as its a perfectly expectable method, just make sure if its PME that there isnt any extraneous bonding in the new shed. Make sure there not going to ask for Infrared heaters as your 4mm will struggle.
As Tomspark mentions - if the 'bar' will only be a small load and it is a pain to route the SWA, then run from a FCU in the house spurred off skt ring. There is a IET Wiring Matters regards this very arrangement - see attached.
Otherwise, unless there specific bonding requirements in the shed i.e. copper water pipe, Jacuzzi; then run a 3C SWA (suggest > 2.5mm^2) - no need for a dedicated rod. (Subject to how far away 'bar' is from house ideally less than 10mtr)
  • 2005_16_autumn_wiring_matters_electrical_installations_outdoors.pdf
Excellent reading! Thank you for providing it, and your advice.
Reply to Power to shed. Thoughts? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, I'm a DIY'er looking to build a 6x8 shed in my backyard in Colorado. I'm installing a gravel pad first, with 4 concrete Sonotube...
Can a domestic consumer unit feed another consumer unit, via the Main Switch. Details are: domestic property with 100A single phase supply...
Hi, I have a client with a small caravan site, approx 5 hookups. His old toilet block was nothing much more than an old shed. He's now 'upgraded'...
Hi All I'm new here. I have just finished my NVQ and waiting to do my AM2. I have a question on selectivity as it has always slightly confused me...
I've wired some cable to a small 3x3 shed with 2 gpos, a 15a GPO, and a light. The shed is about 2m away from the house on a concrete slab. The...
